Clutch Replacement
Nov 4, 2005 | 02:25 PM
Clutch Replacement
Hi again, quick question... at what HP and TQ level should you start to consider replacing the clutch?
Nov 4, 2005 | 06:32 PM
RE: Clutch Replacement
Depends on what you're doing with it. I smoked the stock clutch doing dry burnouts on drag radials w/ ~300ft/lbs of torque.
I smoked the Centerforce clutch going into 3rd gear w/ ~400ft/lbs on slicks.
The Clutchmaster FX700 rocks... no slip there.
Nov 6, 2005 | 11:05 PM
I, on the other hand, am still running the stocker at 61K. Its ready now, though, this last 15K with Stage 3 has taken its toll.
Nov 7, 2005 | 04:18 PM
I hear ya on that one.... Any opinions on the Mopar "Performance" replacement clutch?
Nov 27, 2005 | 03:48 PM
I have the Mopar clutch and no problems yet. Seems to be able to handle 2nd gear starts for a long smokey burnout.
Nov 30, 2005 | 01:26 PM
Whatcha got under the hood though? Are you runnin' stock or with up grades?
Nov 30, 2005 | 09:35 PM
cm s4 6 puck....
Dec 12, 2005 | 11:38 PM
seams like the clutches dont last any where near as long when you use slicks.
Dec 13, 2005 | 12:22 PM
I'm running a SPEC stage 3 in my car. Holds the power great (452hp on pump gas), and is still very driveable on the street.
Dec 18, 2005 | 12:55 AM
i replaced mine when i got over 450+tq it started slipping on a dyno pull at 4700rpm's and after that i got the spec stage 5
