30k Tune/Check Up
Old Nov 7, 2005 | 06:50 PM
Plan B's Avatar
Plan B
Default 30k Tune/Check Up
Other than the suggestions in the manual, does anyone have input/experience on what to check/replace at 30,000 miles? From what I've gathered, there is a substantial amount of useful/need-to-know information that is not covered in the manual.....
Old Nov 7, 2005 | 08:35 PM
PSI Chick's Avatar
PSI Chick
Default RE: 30k Tune/Check Up
all that you need at 30k is a oil change, probably a coolant flush, might want to do the tranny fluid, and a pcv valve. other things like replacing or cleaning the air filter and tire rotation and all are a good idea too. but don't pay the $500 that dodge is going to charge you to do it!!!!
Old Nov 7, 2005 | 09:41 PM
Plan B's Avatar
Plan B
Exactly! That is what spawned the question as well. Dodge charges so much for their milage checkpoints that it makes you think there is some major work required. I planned on doing all but the pcv valve....now that is added to the list. Thanks for you input!
Old Nov 8, 2005 | 07:18 PM
RIPSIGUY's Avatar
RIPSIGUY
ORIGINAL: PSI Chick
$500.00 for a 30k on a 4 cyl??????!!!!! WTF kind of dealer quoted you that price? We charge $280.00.
Old Nov 8, 2005 | 08:39 PM
PSI Chick's Avatar
PSI Chick
i was being sarcastic. but even so, $280 to LOOK at a few parts, do an oil change and fill the fluids is insane.
Old Nov 9, 2005 | 03:21 PM
whatneon's Avatar
whatneon
What do you get for the 280 if you dont mind me asking?
Old Nov 9, 2005 | 03:56 PM
Gump's Avatar
Gump
I would get a voided warenty.
Old Nov 9, 2005 | 04:10 PM
RIPSIGUY's Avatar
RIPSIGUY
Here is what we do on a 30K
LOF
Spark plugs
PCV valve
Transmission oil change
Four wheel balance and rotate
coolant change
lube hinges and locks
fuel filter...if applicable
New wiper blades installed
Inspection or adjustment of the following;
belt tension
exhaust
battery test
all lights
a/c operation
cv boots
pads and rotors
suspension components
Call around, if you can find someone to do all that for $280.00 I'd be surprised.
Old Nov 9, 2005 | 04:11 PM
RIPSIGUY's Avatar
RIPSIGUY
ORIGINAL: Gump
Gump, that went right over my head. I don't get it.
Old Nov 9, 2005 | 05:44 PM
PSI Chick's Avatar
PSI Chick
ORIGINAL: Gump
haha me too. i'm surprised i haven't gotten that letter already!
