Lowering the SRT
Old Nov 15, 2005 | 03:29 AM
Andy4.7's Avatar
Andy4.7
Default Lowering the SRT
Ok, well I will definetly be lowering the car, it needs it bad...
I've tried reading up on this, and just like most everything else theres so many different opinions it's really hard to figure out what to do... It seems like doing just springs might not be worth it in the long run? Price isn't that important, but $200 is a lot nicer than 1000+
If I don't go with springs, I'm looking at mopar stage 2 or the IPP coil overs. Whats the difference between them? Do you just need the coil over set, or anything else? I assume you would have to have the front end aligned after regardless which way you go?
I just need some direction... I'd like to get rid of all the gap, but of course ride and handle good. Anyways, just a little help please. Thanks
Old Nov 18, 2005 | 09:17 PM
Andy4.7's Avatar
Andy4.7
Default RE: Lowering the SRT
No opinions, eh
Probably will just get the mopar stage 2s I guess.
Old Nov 19, 2005 | 01:22 PM
PSI Chick's Avatar
PSI Chick
if you are going to go with co's, do it right. get either the mopar stage 3 co's or the ipp fully adjustables. they are comprible. the ipp non-adjustables are similar to the mopar stage 2's. you can't adjust dampening on them. now for some people this isn't a big deal, but if you go to the track and/or like to be able to adjust your suspension to your tastes, this is an important feature.
i'm not sure what else you're looking for. if there's another question you have that i didn't address, please ask.
Old Nov 19, 2005 | 05:10 PM
Andy4.7's Avatar
Andy4.7
I wasn't considering the fully adjustable ones because I don't really ever plan to go to the track, and figured the stage 2s would be "good enough". But I just checked the prices and the IPP fully adjustables are actually cheaper than the stage 2s, so I might just go with those then. I'm not as much concerened about price as much as having quality stuff, but of course a couple hundred bucks saved always helps.
Also, whats the install like for coilovers? I'm really not familiar with this type of suspension. And is there anything else I need with the coilovers? Front end alignment? And one last thing lol, they're height adjustable, so if you change the height from time to time, does that mess with the alignment, or anything else?
Thanks
Old Nov 19, 2005 | 07:29 PM
PSI Chick's Avatar
PSI Chick
co installation isn't that hard, but you do need a spring compressor. if you're not that familiar with suspension installations, i would suggest taking it to someone that is. you can do it yourself with the proper tools, but most people don't have a spring compressor just sitting around their garage!
yes, you need an alighnment after installing co's. badly. and yes, if you change ride height you'll need to get another alighnment as it will change camber and toe along with height.
Old Nov 20, 2005 | 06:01 AM
Andy4.7's Avatar
Andy4.7
Damn, I don't know where I'd go to have them installed around here. And I wonder how much it'd cost. I imagine the a dealership could install the mopars. Hmm I'll have to look into my options here I guess.
Think that about answers all my questions as far as this topic. Thanks
Old Dec 9, 2005 | 02:28 AM
black4's Avatar
black4
how much are the ipps and who sells them?
Old Dec 9, 2005 | 06:41 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: black4
The non adjustable dampening are around 599 and the 34 way adjustable dampers are 999.
I'll get back on who is selling them if no one else has a place.
Old Mar 18, 2006 | 08:12 AM
vaughn's Avatar
vaughn
cheapest place for the ipp's adjustible and non adjustible http://www.xtremeracingandsound.com/...cPath=64_71_83
Old Apr 30, 2006 | 09:34 PM
TurboPowered's Avatar
TurboPowered
For the Mopar Stage 1's you don't have to get an alignment do you? Does anyone have a picture with Stage 1's? Thanks.
