Weird Idle....
Old Nov 18, 2005 | 02:50 AM
LilSparkPlug's Avatar
LilSparkPlug
Default Weird Idle....
So Im at the gas station tonight with my buddy Anthony (who has an 05 OB SRT) and I leave the car running (so Anthony could continue watching Biker Boyz) to go in and get some orange juice and such. I come out about 5 minutes later, and I hear a car idling funny. Im like WTF???? Thats MY CAR....yay here we go again.
I go around the back of the car to make sure it was mine and not the 1985 Corolla type vehicular object parked next to me still running. Sure as **** it was.
Idling around 950-1250 bouncing up and down erratically like a ****. I revved it and it bogged on me. So I shut the car off turn it back on and it does it again. Shut it off again, let it sit for a minute or two, turn it back on and hes fine.
IAC??? TPS again?
Im lost...hes never done this before. Which doesnt surprise me much LOL.
Old Nov 18, 2005 | 03:22 AM
PSI Chick's Avatar
PSI Chick
Default RE: Weird Idle....
could be tps, could also be a poped or loose vacuum line. check the major vacuum source line that runs behind the intake manifold. mine popped off and amoung other problems caused a funky idle. sounded like i had some serious cams in the thing. the line that runs off the tb is another place to check. also check the lines at your solinoids, i don't think any of these could cause a idle like that (as i've blown most of them and haven't had that happen) but you never know.
Old Nov 18, 2005 | 10:48 AM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: PSI Chick
CHeck the green line behind the battery, as well.
Sounds like another bad tps, though - wierd since it is already your second, but then again your baby is wierd.
Old Nov 18, 2005 | 11:43 AM
PSI Chick's Avatar
PSI Chick
the green line is the brake booster line. that popping off will cause your brakes to fail, but wouldn't effect idle (yes, i've blow that one too. twice.)
Old Nov 18, 2005 | 05:01 PM
LilSparkPlug
Yeah I lost my brake booster a couple weeks back, so the little green line is fine. Ill check all of those lines tonight, maybe it was just a freak occurence, but I cant see why it would do it just once, unless there was an underlying cause.
Yes my baby is very weird Poor little guy.
Old Nov 18, 2005 | 09:34 PM
wozman78's Avatar
wozman78
i know you have heard this a thousand times but....i feel so sorry for you Lil
Old Nov 19, 2005 | 02:28 PM
LilSparkPlug
All the lines are fine, theres no vac leak anywhere. Ill wait and see if he does it again. If so Im leaning towards the TPS....yet again.
Old Nov 23, 2005 | 04:30 AM
BlackDragon's Avatar
BlackDragon
Were you getting gas?
Old Nov 26, 2005 | 02:37 AM
LilSparkPlug
LOL! I know what you mean, but I had to laugh at the way it was worded. I am under the suspicion that something is wrong with the fuel system. I know for a fact that the floater is off, seeing as my gas light doesnt come on until the needle is BURIED in the gauge in the dash. Theres nothing wrong with ANY of the other guages, except that one. Its going in monday....again. We'll see what happens this time. Ive got 1500 miles left on warranty....then Im done. So it all needs to be done...like now.
