AIR FUEL GAUGE?
Old Nov 18, 2005 | 03:46 PM
flameredsrt's Avatar
flameredsrt
Default AIR FUEL GAUGE?
I was looking at getting my gauge pod with gauges(pyro and air fuel).My ? is the srt air fuel gauge says that you need to buy some special harness to hook it up with the o2 sensor, is this true or are they trying to get me to buy something i dont need?thanx in advance
Old Nov 18, 2005 | 04:08 PM
Gump's Avatar
Gump
Default RE: AIR FUEL GAUGE?
well if all you want is a gauge then no you dont need to buy anything else... if you want your gauge to read anything then yes you need to buy a wide band or narrow band which will need a bung in your dp or exhaust. If i were you id spend the extra amount and get a wideband instead of narrow because a narrow is harder to read. its always jumping all over the place.
do you plan on getting your car tuned? or higher mods than what you have? if not i wouldnt bother since its not really a gauge that you will watch on an everyday basis. its pretty much for tuning and trouble shooting.
Old Nov 18, 2005 | 04:33 PM
flameredsrt
As of right now im just doing minor mods untill the first of the year rolls around(tax time)than i plan on doing stage 2 w/toys.I will probably end up going with a wideband but i just wanted to see.In order to use that srt one you have to buy there harness as well,its almost $200 for the gauge and harness,i just wanted to see if that was worth the money and if you actually needed the harness.....thanks for the input
Old Nov 18, 2005 | 05:33 PM
PSI Chick's Avatar
PSI Chick
$200 for a gauge and harness for a wideband? that's either a really good deal or a cheap *** gauge. i got a great deal on my wideband and paid $350 for it! when it comes to these gauges, don't be cheap. if you're going to get one, get a good one.
Old Nov 19, 2005 | 02:14 AM
Gump's Avatar
Gump
yeah point me in the direction of a 200 dollar wideband. and its not needed for s2 unless your going to be messing with it tuneing wise.
Old Nov 19, 2005 | 12:52 PM
flameredsrt
I dont know where you guys got the idea of a $200 for a wideband....i said the srt auto meter(from mopar) w/the harness they say that you need to hook it up is $200....My? was if i was to but the srt auto meter gauge from mopar do i have to but the harness as well or is there a way around it...........
Old Nov 19, 2005 | 01:25 PM
PSI Chick's Avatar
PSI Chick
oh so this is just the autolite narrowband a/f. in that case, yes you need the harness to make it function. but in reality that gauge is nothing more than a pretty light show. save your money and get a real a/f wideband that you can actually use.
Old Nov 10, 2006 | 01:36 AM
street demon's Avatar
street demon
WILL ANY UNIVERSAL WIDEBAND FIT MY MAXXFAB DP AND WILL IT WORK WITH THE AUTOMETER A/F GAUGE?
Old Nov 10, 2006 | 04:20 PM
hozay@N2MB's Avatar
hozay@N2MB
Yes and No. What you have is the $55 light show correct? The narrowband? It's completely worthless. A good wideband will cost you no less then $200 (without a gauge) and about $260 or so with one. Depending on what model.
Looking for the cheap route but want a good wideband? Pick up an Innovate LC-1 wideband $199 and add a dynotune gauge for $89. Or you can skip the whole process and pick up an Innovate XD-16 set which retails for $399 but is the best of the best out there.
Old Nov 10, 2006 | 05:21 PM
street demon
Yea thats the one i just picked up the Innovate LC-1 wideband but i didnt pay $199 I got for only $79. Im going to be useing the autometer mopar a/f raito gauge. Is that ok?
