boost gauge
Old Dec 12, 2005 | 12:39 PM
05dodgesrt4's Avatar
05dodgesrt4
Default boost gauge
sometime when im get into the gas pretty good my boost gauge shoots up and then looks like its just vibrating there is this normal how can i fix it thanks
Old Dec 12, 2005 | 01:33 PM
srt4babe's Avatar
srt4babe
Default RE: boost gauge
my best advice to you is just get the boost gauge replaced. For some reason in all of the '05's there is at least one problem with the boost gauge. I replaced mine and its working lovely!!!
Old Dec 13, 2005 | 01:55 AM
Andy4.7's Avatar
Andy4.7
My 05 boost gauge still works 3800 miles
Old Dec 13, 2005 | 03:04 AM
PSI Chick's Avatar
PSI Chick
what do you mean vibrating? the needle is shaking? if so, then you probably have a boost leak.
the boost gauge can tell you things other than just psi levels, don't be so quick to assume that it's a bad gauge.....
Old Dec 13, 2005 | 07:25 PM
05dodgesrt4
yes its shaking and i believe it is a boost leak cause i cant get more than 12lbs and when its there it shakes and drops i have 2300 miles on it
Old Dec 14, 2005 | 03:09 AM
PSI Chick's Avatar
PSI Chick
where are you located? 12psi in cold weather isn't that bad. and also remember that just because your gauge reads 12psi doesn't mean that's what's getting into your motor.
Old Dec 14, 2005 | 08:30 PM
05dodgesrt4
im in missouri and its been 20-30 degrees im having it checked out at the dealership tomorrow
