tighten those clamps
Old Jan 10, 2006 | 03:47 PM
whatneon's Avatar
whatneon
Default tighten those clamps
what a difference, wow. I am going to go over the turbo piping on a very regular basis now. should be right up there with the occ.
Old Jan 10, 2006 | 03:51 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: tighten those clamps
Everyone should. I think that I am about due, come to think of it.
Old Jan 10, 2006 | 05:55 PM
BigE's Avatar
BigE
I was planning to re-torque mine every oil change. But after only 1000 miles since my last oil change, mine are loose again! Do you think it is engine / road vibration or the pressure in the hose that loosens them over time? Should I check them more often if I am hard on the car, say after I put on a few mods. Like this weekend when I installed the mopar exhaust and BOV. I only have about 3800 miles on my car, and I'm trying to get a mental picture of my maintance schedule.
Old Jan 10, 2006 | 05:57 PM
highline95jl's Avatar
highline95jl
Sorry wrong section
Old Jan 10, 2006 | 06:26 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
My OCC clamps and IC clamps work loose no matter how hard I drive, so I'd have to say it's vibration from the engine and road....my OCC gets emptied every 1000 miles, so a clamp check will be added to the "do list".......
Dusty
Old Jan 10, 2006 | 07:05 PM
whatneon's Avatar
whatneon
I would guess temperature cycles are mostly to blame, with internal pressure and vibration. I design heat exchangers and boilers, at work there are always problems with "hot" (>800deg F) flanged and bolted connections leaking due to the bolts relaxing during thermal cycling.
Old Jan 10, 2006 | 09:20 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Good point. I doubt my OCC clamps get all that hot, the plastic can and rubber hose would be the first to go!!!
Dusty
Old Jan 11, 2006 | 01:28 AM
STANMAN's Avatar
STANMAN
What clamps need to be checked regularly? Is there a sticky, and if not, why isn't there???
Old Jan 11, 2006 | 03:06 AM
Andy4.7's Avatar
Andy4.7
