100 octane fuel
Old Jan 13, 2006 | 01:13 PM
05dodgesrt4's Avatar
05dodgesrt4
Default 100 octane fuel
is it safe to run 100 octane fuel with my mods listed below thanks
Old Jan 13, 2006 | 01:27 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: 100 octane fuel
ORIGINAL: 05dodgesrt4
It's always "safe" question is will it do anything for you. If you can advance the timing and fuel curve...then yes. If not then it may be a waste, and even rob you of a little power as I understand it.
Old Jan 13, 2006 | 01:48 PM
got boost?'s Avatar
got boost?
To be able to run 100 Octane effectively you'd need Stage II with Toy which uses a high Octane mode as Adam said before advances the timing to accommodate.
