Only 12 psi of boost?
Old Jan 20, 2006 | 12:18 AM
Andy4.7's Avatar
Andy4.7
Default RE: Only 12 psi of boost?
If you hit 20psi stock, you got a problem...
Old Jan 20, 2006 | 01:20 AM
blue_srt4's Avatar
blue_srt4
20psi? did the check engine light come on? sounds like overboost to me.
Old Jan 20, 2006 | 02:44 AM
LilSparkPlug's Avatar
LilSparkPlug
You can hit 20psi stock. If your in 5th gear at 30mph and you peg the gas. LMFAO Ive done it in an SRT, and my friend did it in his SRT too... So you really aren't hitting it, your just f'kn with the computer.
But if your hitting 20psi with normal driving.....ummm negative soldier your gauge has **** the bed. Tally-ho to the dealer for a new one
Old Jan 21, 2006 | 10:21 PM
black4's Avatar
black4
lmao what is it with you and soldiers crystal im sorry lmao. to add to this where i live the boost is pretty steady never had any change in boost.
Old Jan 24, 2006 | 12:33 AM
JayDubb105's Avatar
JayDubb105
Like everyone else said,keep babying it but open up the gears a little every now and than.In a couple months you will get around 1500 miles or so(depending on how you drive)and see how your boost levels are looking then,they should have increased and you should most defanitely notice it through all gears but mostly 3rd and up.Hope we all helped,goodluck!
