Tires/Performance
I just put new winter tires on my '04 SRT and they are 15', I traveled from NY to Colorado, and when on the highway whenever i reached about 70-80 mph my steering wheel began to shake, is this normal due to the smaller tires then the stock ones or do i need to get something looked at?
ok, even though you went to 15 inch rims, depending on the size of the tires, you really shouldn't have vibraiton issues. First off, did they use hub-centric rings on the rims you bought???? Also, its very possible the balance on the rims/tires is off. Also, if I remember right, when you go with an aftermarket rim, you have to remove a crush washer on the hub, or the rims won't sit totally flush.
ORIGINAL: Qdiddy
yea they have hub centric rings, i'm gonna check on the hub washer though thanks
