Help with stage 2 PCM !!!
Old Feb 12, 2006 | 10:43 AM
black4's Avatar
black4
Default RE: Help with stage 2 PCM !!!
those bolts are no joke just about skinned every knuckle getting those off not fun.
ORIGINAL: Andy4.7
So, did you get the PCM plugged in?? It was hard to follow that paragraph lol
Check the pins and make sure they're not bent or something!
Atleast you don't have to worry about that heatshield... I had to cut a slot in mine to reach the arm after stripping two of the bolts right by the WGA! The good thing is, I can adjust the WGA in a couple minutes, the bad news, I don't like doing stuff like that and it doesn't look the greatest.
Which leads me to one quick question for you... Did the guy make sure the WGA was adjusted properly?
