BOV & STS
Old Feb 9, 2006 | 05:09 AM
MikeyLittle's Avatar
MikeyLittle
Default BOV & STS
What's up people, just a few quick questions here. What should I know about before I install the Mopar BOV and Short Throw Shifter. I know about the dreaded third bolt lol but i also heard about replacing a spring. If so can someone enlighten me on this. Also with the STS, what the hell is booger bushings that I hear people talking about and does it help, I know I don't have to change the boot for it but will the Shift **** fit or does it come with one already?? Any help would be appreciated, thanks guys/girls
Old Feb 9, 2006 | 12:56 PM
manninej's Avatar
manninej
Default RE: BOV & STS
As far as the BOV goes, this is the how to that I used and it makes it really simple.
http://planet1041.com/BOV/frame.htm
Here's a couple of tips. Use a ratchet wrench...if you don't have one, get one. Tie a string onto the wrench and around your wrist so you don't keep loosing the wrench. Get some extra bolts and washers. I dropped on of mine and couldn't find it, so I had to rig it so that I could get up to Lowes and get some more bolts. They only cost about $2 for a few of them and you'll be glad you got them if you loose one.
Old Feb 9, 2006 | 02:26 PM
LilSparkPlug's Avatar
LilSparkPlug
ALOT, okay just about everybody that buys the Mopar STS gets those bushings. I dont have them, and I love the way my car shifts. My friend does have them, and his car shifts exremely stiff. I dont know if he installed them wrong or what, but I dont like those little things.
Old Feb 9, 2006 | 06:14 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: MikeyLittle
forget the spring - unrelated. **** will fit, but may or may not come off easily in 2nd - i never had a problem. - if you do get a replacement htat is weighted - you will like the weight as it helps it into gear. MOdern has a good one for 50$
Old Feb 9, 2006 | 08:03 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
You also might want to put a little Permatex Hylomar HPF gasket dressing on the BOV gasket when you put it in. It'll help to prevent leaks. Fussing with your BOV isn't anyone's idea of a fun time.....
Dusty
Old Feb 9, 2006 | 09:37 PM
LilSparkPlug
ORIGINAL: dustyloins
Dusty
x2 I agree wholeheartedly forgot about that one
Old Feb 10, 2006 | 07:46 PM
MikeyLittle
thanks you guys/girls been a real help, i get everything in in about 3-5 days and ill def. let ya know how things turn out
Old Feb 10, 2006 | 09:02 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Sounds good!
Dusty
