DAB and manual boost control any way to make it work??
Old Feb 11, 2006 | 01:54 PM
BlackZSlayer's Avatar
BlackZSlayer
Default DAB and manual boost control any way to make it work??
I tried to search for it but had no luck and I know its probly been discussed many times but any help would be great. I just talked to one of the guys at modernperformance and he old me I should try to raise the boost to get some more power out of my stage 2 with toys. He said with the extra fuel that I can safetly run 19-20psi with no problems. I just would like to know if hooking a manual boost controler would keep me from using DAB because I really like the chose of choosing what boost levels I want. Also if that wouldnt work is there any way a different wastegate could hold more boost and still let the DAB work. I appreciate your help and knowledge. Thanks
Old Feb 11, 2006 | 03:21 PM
PSI Chick's Avatar
PSI Chick
Default RE: DAB and manual boost control any way to make it work??
using a mbc will not allow you to use the dab. when you install a mbc you take away control from the ecu, which is how dab works.
you can use a new wga to help hold more boost, and it might help, but don't expect a miracle. toys was designed to run in certain perameters, and the ecu will pull timing if it sees things outside of what it expects. i'd suggest investing in a good w/i, that will actually help you get more power out of a s2 than a wga. not that a wga is harmful, just that it's not going to help all THAT much.
Old Feb 12, 2006 | 10:34 AM
black4's Avatar
black4
amen to w/i im living proof ofwhat it does for stg2 psi chick.
Old Feb 12, 2006 | 04:32 PM
FSTSRT4's Avatar
FSTSRT4
With my stage 2 without toys, I installed an AGP wga (old style). I connected it to the stock lines. I was able to pull 1-2 psi more initial boost than with the stage 2 wga. It seemed to hold more boost at redline also. This might be an option for use with the Dab.
Old Feb 12, 2006 | 04:34 PM
FSTSRT4's Avatar
FSTSRT4
ORIGINAL: black4
agreed, with W/I and stage 3 HOM is my friend......
Old Feb 13, 2006 | 03:49 AM
PSI Chick's Avatar
PSI Chick
w/i is a great thing...just got mine in the mail last week, still have to install it though....damn snow.
Old Feb 13, 2006 | 12:36 PM
MChat's Avatar
MChat
I have a way to make DAB work with a MBC, but it is not a simple design. It involves the use of a Vacuum/Boost solenoid and a pressure switch...
If you're interested in complex setups, I'll post up.
Old Feb 14, 2006 | 03:53 AM
black4's Avatar
black4
you will love it. which one did you get?
ORIGINAL: PSI Chick
Old Feb 14, 2006 | 04:26 AM
PSI Chick's Avatar
PSI Chick
got the devil's own dual 3gph nozzle stage 1 set up....should be plenty to hopefully keep me in hom!!!!!
Old Feb 20, 2006 | 12:15 AM
BlackZSlayer
Just would like to know with the stage 2 how would w/i help me and what do you use to do it. I kind of need the basics explained to me. Hope its not to much trouble. Thanks.
