91 vs 93?
Old Feb 13, 2006 | 07:39 PM
bmansrt's Avatar
bmansrt
Default 91 vs 93?
Since moving from pittsburgh which had 93 to SoCal which i can only find 91. Is this bad its still premieum fuel but i was just thinking about it the other day and it was bothering me. So if you guys/girls can help me out that would be awsome!
Blake
Old Feb 13, 2006 | 07:59 PM
BB's Avatar
BB
Default RE: 91 vs 93?
This is what I read. Octane rating does nothing for making your car run better. It helps to eliminate spark knock or ping. Depending how much you have done to your engine will determine what octane gas is good for your car. I run 89 octane because I am completely stock and my engine doesn't ping. The more you advance your timing by Stage 1 or 2 or 3 or other goodies, will determine how much octane your engine will need. In other words, your engine will tell you how low you can go on octane. You don't want it to ping and I wouldn't run lower than 89 octane. Hope this helps on your decision.
Old Feb 13, 2006 | 08:10 PM
BB's Avatar
BB
Forgot to add where I read that stuff.
www.ftc.gov/bcp/conline/pubs/auto/octane.htm
Old Feb 13, 2006 | 09:07 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I agree, 91 octane should be OK provided you don't mod your engine too much. You can always add a few gallons of racing gas if the situation calls for it......
Don't waste your money on the "octane boosters"....
Dusty
Old Feb 13, 2006 | 09:54 PM
LilSparkPlug's Avatar
LilSparkPlug
All we have here is 93, I would never run ANYTHING below 91.....ever. But people in Cali run 91 all the time with no issues.
Old Feb 14, 2006 | 03:55 AM
black4's Avatar
black4
the nos octane booster is the shisnet it allows me to hold hom on pump gas.
ORIGINAL: dustyloins
Dusty
Old Feb 14, 2006 | 05:18 AM
posthondaremoval's Avatar
posthondaremoval
WERD, black.
Loves me some octane booster!
But word to the non hom running peeps, in seriousness:
91 octane will run safely. However it has been tested through numerous sources to be true that timing can be pulled with 91. I might try running a little booster after reseting the ecu for for a tank, and letting the ecu learn that map. Just as a test, you might find gains. Couldn't hurt to try.
