Silverstar's
Sylvania (is that spelled right) website should help with the p/n's.
should be pretty easy-peasy to change... it's just the bulb's right? reach in, twist, pull out... replace, push in, twist... done. wow, sounds like my personal life (joking)... hahahahaha
Not too sure on a part number but i know advance auto parts has them....They are fairly easy to put in i found that removing the driver side headlight helps a bunch...hope that answer's at least one of your ?
welcome back amanda havent seen you for a while!!!!
You don't need to remove the headlight to get at the bulbs, it is a little tight, but it can be done.
Trending Topics
Headlight - 9007
Turn Signal - 3157
Sidemarker - 194
Foglight - 893/899
Fog lights are just as easy, you dont need to remove the housing or anything, just takes a bit of practice to get it in there. With the stock intake the driver's side headlight can be a PIA.....but just pop the top of the box off and it makes life easier.
Turn Signal - 3157
Sidemarker - 194
Foglight - 893/899
Thanks everyone, I think just for now I am going to do the turn signals, but I also ordered my BOV and intake, which will be the first adds to my car, woo hoo!!!!
Thank god for credit cards!
Amanda
Amanda
ORIGINAL: srt4babe
Amanda
Amanda
