oil pressure gauge
Old Mar 1, 2006 | 03:32 PM
1fast04neon's Avatar
1fast04neon
Default RE: oil pressure gauge
ok i have one more question for you.... last night i was doing some pulls with another srt and i spiked at like 24 lbs on s2. ended up that the vaccume line to the wastgate was cracked. i put it back together and now im only getting 7lbs. its a brand new turbo has 1300 mile on it. also i see back dots all over the back bumper i dont know if it was a seal or just b/c im running so rich now do u have any idea of what happend
Old Mar 1, 2006 | 05:09 PM
BigE's Avatar
BigE
The computer was probably trying to correct the overboost issue for you. Now that you have fixed the vacuum line, try re-setting the ECU by disconnecting the battery for about 15 minutes. Also at 24lbs of boost, you may have blown off other vacuum lines from their connectors, always a good idea to check all the ones you can see.
