AGP wastegate need advice....
Old Feb 25, 2006 | 11:18 AM
roachnigga's Avatar
roachnigga
Default AGP wastegate need advice....
Ok...
I have read different set-up on with the wastegate. Meaning which line to Cap [green & blk] and use the blue line. Or should i go with what the instructions say on what AGP refers...
Second: What will be a safe boost to redline you guys recommend... I myself shootin for 17 psi with my set-up on what i have on my car... any opinions? appreciated...
Peace
Old Feb 25, 2006 | 03:18 PM
rx8driver's Avatar
rx8driver
Default RE: AGP wastegate need advice....
I used the agp instructions to install mine. Someone stole all of my colorful lines.[sm=badbadbad.gif]
17 psi at redline on stage 2 sounds good to me but maybe someone with stage 2 can chime in.
Old Feb 25, 2006 | 06:37 PM
roachnigga's Avatar
roachnigga
Thats what thought, too. thnx for ya advice rx[sm=chattypair.gif]
Old Feb 25, 2006 | 07:17 PM
05dodgesrt4's Avatar
05dodgesrt4
what color do the directions say? and off subject but to increase boost do you make the arm shorter or longer?
Old Feb 25, 2006 | 08:27 PM
roachnigga's Avatar
roachnigga
The instructions states to remove the green & blk lines from the selinoid and run the green line to the wastegate. Now i also read that the blue line can be use. But, you have to cap the green & blk. Now, if im correct, the blue line deals with the brake system... but others swaar by-it to tap on the blue...[&:]
For more boost the arm must be shorter i.e more tension...
Old Feb 26, 2006 | 12:52 PM
roachnigga's Avatar
roachnigga
Never mind i just finished installing. Now i have to tune it... i left alot of slack, about 3mm of play, and i hit about 10.5 psi on my 1st run. Then it began to snow[]... BUMMER...
Appreciate all that gave suggestions...
Peace
Old Feb 26, 2006 | 04:05 PM
05dodgesrt4
which way did you hook yours up roach?
Old Feb 26, 2006 | 05:48 PM
roachnigga's Avatar
roachnigga
went the green line way
Old Mar 2, 2006 | 05:18 PM
1fast04neon's Avatar
1fast04neon
im havin the same problem. i got the s2 kit and i just hooked it all up the same way but i only get 10 lbs in first gear and all the others i hold at 15lbs. i wanta hold alittle higher what adjustment do i need to make??
Old Mar 3, 2006 | 09:46 AM
BigE's Avatar
BigE
1fast04neon, you are not alone. Flameredsrt just went though the same thing. Start with this thread and go from there...
https://dodgeforum.com/m_398114/tm.htm
