Oil Catch Can Finally
Old May 16, 2004 | 08:01 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Oil Catch Can Finally
Yup, always nice to see a well maintained SRT-4...!![&:]
Old May 16, 2004 | 08:40 PM
roachnigga's Avatar
roachnigga
SWWEEETTTT
Old May 17, 2004 | 09:11 AM
71RoadRunner's Avatar
71RoadRunner
Well, it only took till today. It now has a small amount at the bottom of the OCC.
Old May 17, 2004 | 03:42 PM
roachnigga's Avatar
roachnigga
I havent got any yet on my OCC. only some residue on my lines...[&:]
Old May 17, 2004 | 04:43 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I never did see any in my GReedy catch can, either, but if you see residue in the line, then chances are there is some in the can...it just isn't enough to show up in the sight glass...because the $20 OCC is clear (the bottom 2/3's of it anyway), you can see the first drops of oil right away...[sm=smiley4.gif]
Old May 17, 2004 | 05:19 PM
roachnigga's Avatar
roachnigga
COOL...
Old May 17, 2004 | 10:42 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Was looking at the OCC today (about 1/3 full) and when I touched it to check the tightness of the fittings, I noticed a very slight film of oil on the outside of the OCC. I've been pretty regular about tightening the hoses/clamps, and the can is tight to the metal top. I guess this must be seepage from the hoses....it's not a concern, since I put it on a month ago and it hasn't leaked a single drop yet.....just a FYI.....[&:]
Old May 18, 2004 | 10:58 AM
71RoadRunner
Hey roach, I noticed that your hose for your catch can seems to be pinched almost closed in your pics as it goes into the CAI.
Dusty, did you use teflon tape or a thread sealer before putting the ends into the OCC, that may be where it's leaking from.
Old May 18, 2004 | 11:04 AM
roachnigga's Avatar
roachnigga
RR, Yeah it was an accident on my part... i had to heat up the line to apply to the CAI. ... I heat it up a little tooooo much... DOH!!![:@]
Old May 18, 2004 | 11:21 AM
71RoadRunner
If it can't breath properly then I'm sure it will be blowing more past the PCV.
