sparkplugs
Old Feb 28, 2006 | 09:32 AM
m88s22's Avatar
m88s22
Default sparkplugs
just wondering what is the best plug and also gap for them.
Old Feb 28, 2006 | 09:58 AM
BigE's Avatar
BigE
Default RE: sparkplugs
What kind of mods are you running? Because the different stage kits require different plugs.
Old Feb 28, 2006 | 10:41 AM
SRT_YA's Avatar
SRT_YA
NGK is the best... but I'm biased... ha-ha... as long as it's not Champion you are in a whole lot better place!!!! Denso makes a good plug too, but I'd stick with the NGK's... ha-ha...
Old Feb 28, 2006 | 11:03 AM
m88s22's Avatar
m88s22
stock for now.
Old Feb 28, 2006 | 11:46 AM
PSI Chick's Avatar
PSI Chick
ngk 4306 gapped to .045 and you should be good!
Old Feb 28, 2006 | 06:03 PM
LilSparkPlug's Avatar
LilSparkPlug
I just got Iridiums and they're like .052. That okay PSIChick?
Old Feb 28, 2006 | 07:02 PM
SRT_YA's Avatar
SRT_YA
if you have the proper voltage... opening the gap is fine ;-) it actually helps the flame propogation... however, you have to be careful of voltage sparking to the metal shell vs. the ground electrode if you open the gap too far... also, I think iridium plugs from NGK come pre-gapped and shouldn't require regapping... just some FYI for ya...
Old Feb 28, 2006 | 07:09 PM
PSI Chick's Avatar
PSI Chick
yup he's got it! irridiums in general use a higher gap than a copper plug will.
which irridiums did you go with crystal?
Old Feb 28, 2006 | 07:35 PM
SRT_YA's Avatar
SRT_YA
ORIGINAL: PSI Chick
it's good to know I learned something at work hehehe
Old Feb 28, 2006 | 09:18 PM
LilSparkPlug
I have no idea, I ordered them from NAPA, and I just said NGK Iridiums...I can check the reciept and Im picking them up tomorrow, all I know is that the reciept says they are gapped .052
