Launches
Old Mar 1, 2006 | 01:42 AM
whoosh's Avatar
whoosh
Default RE: Launches
Off topic, but MChat, whats the 2-step?
Old Mar 1, 2006 | 04:50 AM
Pressurecooker's Avatar
Pressurecooker
He's referring to a rev limiter that has 2 rev limts; a low one for launches and another higher one for the upper rpm limit, usually a microswitch set to be "made" in 1st gear or say when the clutch is on the floor, tells the box which limit it needs to be in. Then when the switch is released, it defaults to the higher rpm. That way, you can launch with your gas pedal to the floor and the engine "stuttering" at the preset low launch rpm, and when the switch is "un made or opened" you are already at full throttle. It's a way of using electronics to tune in consistency. Very important in bracket racing.
As far as launches with street tires, my best ones have been at rpm's scarcely higher than a regular street start. Like about 1500 then rolling into full throttle. Any more than about 17-18 hundred and it's all tire spin. (for me) I also usually do the 1-2 shift about 5500. The rest near redline. My car is very stock.
Old Mar 1, 2006 | 12:52 PM
05dodgesrt4's Avatar
05dodgesrt4
is the stock intercooler and return line able to handle 20psi? and rare do you have a stock ic or return line?
Old Mar 2, 2006 | 04:17 PM
rare04's Avatar
rare04
No I have a Agp fmic with turbonetics upp&greddy bov. My brother is runnng the stock fmic and lines and hes not having a problem.
