MOPAR BOV LEAK ???
Old Mar 7, 2006 | 01:31 AM
moparman04's Avatar
moparman04
Default MOPAR BOV LEAK ???
MY BOV IS HISSING WHEN IM NOT EVEN OFF THORTTLE SOMETIMES EVEN WHEN I AM ON THE GAS OR IN VACCUME >>> ANYONE ELSE HAVING THIS PROBLEM ???
Old Mar 7, 2006 | 04:06 AM
PSI Chick's Avatar
PSI Chick
Default RE: MOPAR BOV LEAK ???
welcome to the blue rice plate!
did you make sure that all the bolts are evenly tightened? used copper rtv or a similar sealant when installing?
Old Mar 8, 2006 | 04:51 AM
moparman04's Avatar
moparman04
hmmmm. i did use sealant but not to sure about the bolts being even . i just cranked them down best i could... i dont think they could have picked a harder spot for the thing to go... ill reinstall and let ya know ... thanks !
Old Mar 11, 2006 | 02:26 AM
moparman04's Avatar
moparman04
you are not going to believe what happened !!! i broke off the top bolt when cranking it down !!! but on the up side it stopped leaking[sm=sigh.gif]
Old Mar 14, 2006 | 01:22 AM
TurboPowered's Avatar
TurboPowered
Well, atleast your not leaking thats the most important part
