Official SRT-4 Time Slip & Discussion Thread
Old Mar 20, 2006 | 05:43 PM
  #31
joe0121's Avatar
joe0121
Default RE: Post your time slips.
How much boost does the stage 3 kits run on and what can you realisticly expect this engine to make.
Old Mar 22, 2006 | 05:50 AM
  #32
Pressurecooker's Avatar
Pressurecooker
13's bone stock. Absolutely. Of course we have a good track and are not too high here. (about 400 ft above sea level) You probably wont see 13.8's stock in Las Vegas (hot and 2000+ ft above sea level). The track does make a difference, sure. It was about 56 degrees that day. That was a trade off. Power was up but traction was down. You can see from my time slip I was only pulling 2.1 60 ft times. Good, but not spectacular. Interestingly, on a much hotter day earlier in the summer, I was running about the same trap speeds but not as quick e.t's. The magic day would be about 65-70, sunny and no wind.
Old Mar 23, 2006 | 05:32 PM
  #33
joe0121's Avatar
joe0121
ORIGINAL: Pressurecooker
lol or a very strong tail wind
Old Apr 27, 2006 | 01:35 PM
  #34
flameredsrt's Avatar
flameredsrt
I got my first runs EVER last night
1st run(best run):13.7@103 with a 2.0 60 foot
2nd run:14.0 with a 2.2 60 foot
3rd run:14.1 with a 2.3 60 foot
4th run:13.9 with a 2.1 60 foot
5th run:13.9 with a 2.2 60 foot
6th run:14.2 with a 2.3 60 foot
7th run(worst run):14.3 with a 2.4 60 foot
This is stage 2 w/toys in HOM most bolt ons at bandimere(6000ft)damn elevation!!!
I have drag radials on the car anyone think this should be faster or maybe it would be possible to get my 60's down to 1.9 with some practice?Lookin for some insight from people that have or had this similar set-up and what E.T's and 60"s you where running?
Old Apr 27, 2006 | 02:59 PM
  #35
PSI Chick's Avatar
PSI Chick
wow there's quite a lot of leg humping going on around here.
my best times - 13.8@101 bone stock
to date - a pathetic 12.4@113. i need to get back to the track.....
Old May 22, 2006 | 04:05 AM
  #36
Pressurecooker
Wow I just noticed that all my old posts sigs were upgraded to my latest sig change though they did not apply then. That's going to generate confusion. Well FRSRT, I guess your runs at 6000 ft are ok if you then correct for altitude, but what I'm going to tell you now is going to **** you off. Last friday, at the Srt Nats in Norwalk, I just ran a best E.T. of 13.68 at a mph of 103.5. This is on street radials with a r/t of .262 and a 60 foot of 2.06. I ran a slower e.t when I ran my best 60 of 1.99. The tire is the Fuzion ZRI. 225/55/16 yes 16.
I have a STOCK computer, fmic, exhaust, airbox, coil, turbo, injectors, wga etc. The only engine/power mods are a K&N filter in the stock airbox and Autolite iridium plugs. No springs, clamps or tricks. I do also have AGP motor mounts. Go figure......
It is a black 2004.
Legend has it they are the fastest........
[IMG]local://upfiles/15665/9209A93E64BE4238933C5B99A310F1C4.jpg[/IMG]
Old May 26, 2006 | 01:21 AM
  #37
FlakDodger's Avatar
FlakDodger
2003
HOM mode
BFG 225/45/17 Drag Radials
see below for other mods
Old Sep 19, 2006 | 02:28 AM
  #38
DanSRT4's Avatar
DanSRT4
Im the newb, but not to racing. Heres my best so far, om a miss shift into 4rth...(I should have just held it out in 3rd)
Mods: Highly Modified
They dyno graph shows my first dyno sessions best pull, little fuzzy, but 448 whp. It is up to about 480 whp now that I am running the AEM EMS with a cpl more changes. More info can be had through my links in signature
[IMG]local://upfiles/44738/1F2E8A97AACF4B53A2407F37D0C0D310.jpg[/IMG]
[IMG]local://upfiles/44738/3DE7C313E64149588139ECCF28C54AD9.jpg[/IMG]
Old Sep 19, 2006 | 03:43 AM
  #39
stocksrt4's Avatar
stocksrt4
Default RE: Official SRT-4 Time Slip & Discussion Thread
i was wondering how to post a topic if anyone would let me know it would be greatly apperciated i just joined. Also i was wondering what i can do to my stock srt-4 to make it faster for about 500 to start with?
Old Oct 20, 2006 | 11:44 AM
  #40
GPtuner's Avatar
GPtuner
I've been wondering, whats the BEST E.T. someones been able to get out of a BONE stock SRT4??
