stable boost for stage 1
Old Mar 13, 2006 | 04:32 PM
05dodgesrt4's Avatar
05dodgesrt4
Default stable boost for stage 1
ok i installed the agp wastegate using the factory hoses and i am spiking 20psi holding 17-19 depending on what gear im in 1st is 14psi
2nd spike 19 hold 17 3rd spike 20 hold 18 4th spike 20 hold 18-19 havent done 5th yet
so is this safe on stock fuel system and stock intercooler
Old Mar 13, 2006 | 04:41 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: stable boost for stage 1
Anything over 19psi, the intercooler and turbo dont flow right. Although S1 ups the spark knock from 18 to 24psi
Old Mar 13, 2006 | 04:57 PM
05dodgesrt4
so ill be fine at those pressures that im holding?
Old Mar 15, 2006 | 05:25 AM
black4's Avatar
black4
sounds a little agressive on stg1 mod but i may be wrong.
Old Mar 15, 2006 | 01:48 PM
LilSparkPlug
It is a bit aggressive, your gonna need more fuel for the higher PSIs.
Old Mar 15, 2006 | 03:54 PM
05dodgesrt4
so should i get bigger injectors or what?
Old Mar 17, 2006 | 01:23 AM
BigMac's Avatar
BigMac
I wouldn't set it to exceed 17 with your setup.
Old Mar 17, 2006 | 02:18 AM
LilSparkPlug
If you get bigger injectors you'll need something like an SAFC to control the fuel.
