O2 Sensor needed
Old Mar 18, 2006 | 11:42 PM
300ZXSRT4's Avatar
300ZXSRT4
Default O2 Sensor needed
Ok, while installing the a Mopar SRT-4 A/F ratio gauge, Mopar oil pressure gauge and Mopar BOV (blue plate) conversion I got a check engine light. The car started throwing codes. It turns out that I needed a new O2 sensor. Does this sound right??? Which upgrade would have caused the O2 sensor to go bad or appear not functional?
Old Mar 20, 2006 | 01:30 PM
PSI Chick's Avatar
PSI Chick
Default RE: O2 Sensor needed
none of those would do anything to the o2 sensor. why do you think you need a new o2 sensor? what code was thrown? what other mods are on the car?
Old Mar 20, 2006 | 05:54 PM
300ZXSRT4's Avatar
300ZXSRT4
Doesn't make much sense to me.....
Old Mar 21, 2006 | 04:10 PM
300ZXSRT4's Avatar
300ZXSRT4
Stage 1 with a CAI. Those are the only mods and everything was fine until the installation of the parts named.
Old Mar 21, 2006 | 07:01 PM
PSI Chick's Avatar
PSI Chick
what are the codes
Old Mar 21, 2006 | 08:43 PM
300ZXSRT4's Avatar
300ZXSRT4
P0133 & PO131
Old Mar 22, 2006 | 09:08 PM
300ZXSRT4's Avatar
300ZXSRT4
Just found out.....it is the A/F gauge and evidently it cannot be set up with the stock O2 sensor. You have to get an aftermarket O2 sensor. Doesn't make much sense but oh well. There is another 140 bucks down the drain. Oh yeah, it is reading rich.
Old Mar 23, 2006 | 03:31 AM
PSI Chick's Avatar
PSI Chick
i've never heard that one before...it's the mopar a/f guage so why wouldn't it be able to use the stock o2 sensor? that's weird....
Old Mar 23, 2006 | 04:16 AM
dodgejosh's Avatar
dodgejosh
if ur o2 sensors throw the check engine light it will run rich... because it wont know where lean or rich is... so its safier to run rich than lean.....
Old Mar 23, 2006 | 02:11 PM
300ZXSRT4's Avatar
300ZXSRT4
According to Modern Performance; The Mopar A/F gauge is wideband so you need a wideband O2 sensor.
