valves that blow off
Old Mar 27, 2006 | 05:45 PM
moparman04's Avatar
moparman04
Default RE: valves that blow off
no block off plate for the mopar... it sounds like you want that sort of sound but no worries and cheap... go with the FORGE bov.. my friend had one and it sounded good !! ( yes i said HAD ) he crashed it
Old Mar 28, 2006 | 12:18 PM
MChat's Avatar
MChat
ORIGINAL: shnormo
Also the MASF calculates the air before and after the turbo. With a BOV, the air that has been calculated is purged from the system causing the engine to run really really rich for the few moments the BOV is open. A little damage could be resulting. Block off plates would greatly reduce it, but no matter what, it is registering the air and it isn't there. Your O2 sensors would suffer too.
The SRT-4 doesn't have a Mass Air Flow Sensor; the ECU relies soley on the Manifold Absolute Pressure sensor to determine air flow.
As for the BOV, how loud do you want it to be. The TurboXS RFL (Really Freakin' Loud) is the loudest that I've heard. I use the Raptor BOV, which can hold higher boost pressures and isn't too noisy. In fact I plan on re-routing the "blow off" back into my new airbox. Between that and the missing intercooler, I might just dupe people into thinking that I have an SRT-Design package Neon SXT
Old Mar 28, 2006 | 01:27 PM
whoosh's Avatar
whoosh
ORIGINAL: MChat
ORIGINAL: shnormo
What happened to your IC?
Old Mar 28, 2006 | 02:34 PM
American__Muscle's Avatar
American__Muscle
ORIGINAL: whoosh
ORIGINAL: MChat
ORIGINAL: shnormo
I think he mentioned something about using an AFTERcooler... although I don't know what it is or how it works...
Old Mar 28, 2006 | 05:09 PM
BigE's Avatar
BigE
I have heard people running superchargers and using an aftercooler. Just like an intercooler, but made for supercharged use. Some have a way of stuffing them full of ice or a stand alone cooling system. The SVT lightning uses an aftercooler, and is cooled by engine coolant.
Old Mar 28, 2006 | 11:05 PM
MChat's Avatar
MChat
I'm having a custom Water to Air aftercooler made. It'll use a separate "radiator" that sits up where the intercooler used to be, a water tank that will likely be where the windshield washer tank was, a pump and a air to water heat exchanger which will be significantly more efficient than a large FMIC. Pressure drop should be almost non-existant.
Old Mar 29, 2006 | 01:07 AM
American__Muscle
ORIGINAL: MChat
There's gotta be a reason everyone hasn't converted over then... $$$?
Old Mar 29, 2006 | 02:15 AM
whoosh's Avatar
whoosh
Prolly...
Old Mar 29, 2006 | 01:47 PM
MChat's Avatar
MChat
ORIGINAL: American__Muscle
ORIGINAL: MChat
Cash and no company out there is offering a "kit" to do it. So it all has to be custom.
MetalMan might be able to come up with a "kit" after he does mine. But it's still probably going to cost around $1200-1400. The kit would include new pressure pipes from the turbo to the after cooler and from the aftercooler to the throttle body, plus all of the components of the water to air system (Radiator, heat exchanger, plumbing, tank, pump, wiring, etc...)
Old May 3, 2006 | 06:04 PM
Valo2170's Avatar
Valo2170
You guys know whats funny? I dont understand something.Every one i know along with me says to use a block off plate.But for some reason if you guys go to E.D web site they say not to use one. LOL LOL Im sorry but why the hell would you have 2 places where the air comes out of.hehehe LOLOL I never understood why he said that,but he does on his web page.Me on the other hand used a block off plate and i have never had any problems with it.
