My hot pink powdercoated sexiness!!!
Here's the pix!!
Yes the engine needs to be cleaned, I DID put the hose clamp on the crankcase breather after the picture, and I had to go buy a new PCV valve, mine wouldnt come out of the stock valve cover. Next on the agenda is painting the letters SRT-4 pink on the injector cover which Ill probably do this weekend.
Oh and the residue on the letters is from adhesive, gotta get that off too, but I ran out of time.
Pink pinstripeage!!!
And theres methods to madness, the powdercoater:
(yes its crooked because it was angled for a different rear window)
Its not THAT expensive! From the place I got mine it was $160 bucks for it, if you want clear on it too, its $185. So its not that much of a set-back, unless you wanna do the entire engine. Mine came with all new gaskets and a new oil cap, the only thing it didnt come with that I needed (cause mine wouldnt come out) is a PCV valve
[sm=smiley16.gif]need sungalsses to look at that thing !!! it came out great !
Trending Topics
Well,,,,,,,this coming from a guy who actually has a PINK shirt,,,,,,,I think it looks great!
Are you going to change out the vacuum lines and stuff? If you are, be careful, because with all that pink you could get........
panty lines.
panty lines.
