stage 1
Old Mar 30, 2006 | 11:35 PM
mxrnick's Avatar
mxrnick
Default stage 1
i am not sure but i think i read somewhere that the 05 srt-4 come with the stage 1 injectors. is this correct? does that mean it has the stage 1 ecu too? just asking.
Old Mar 30, 2006 | 11:46 PM
BB's Avatar
BB
Default RE: stage 1
No. The 04 & 05 came with the bigger injectors but still need the ecu for Stage 1.
Old Mar 31, 2006 | 12:11 AM
OrangeBlast99's Avatar
OrangeBlast99
Default RE: stage 1
^^ Yep, comes with stage 1 injectors, but NOT the ECU.
ECU is about 300 bucks and its good for about 10hp/10 ft torque.
Some other little goodies too, read the sticky at the top about the STAGES
Old Mar 31, 2006 | 12:51 AM
mxrnick's Avatar
mxrnick
Default RE: stage 1
thanks for clearing that up
Old Apr 4, 2006 | 09:40 PM
vaughn's Avatar
vaughn
Default RE: stage 1
i just installed mine.took me less than a hour.i have the stock intake.....started right up.....im to tired to test drive it ...did it right after work.....plus im on empty.so i cant wait to feel the difference in the morning
Old Apr 4, 2006 | 11:31 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: stage 1
I've seen dyno charts that show a 10 hp gain w/Stage 1 when used in conjunction with a Mopar/Borla exhaust and a CAI or high flow air filter, but never by itself. My experience has been that the boost comes on faster, the throttle response is better, so the car DOES goes faster than stock, but it's more of a "tuning" thing than a pure HP/Torque gain.....
Dusty
Old Apr 4, 2006 | 11:54 PM
vaughn's Avatar
vaughn
Default RE: stage 1
kinda off subject...but speaking of the borla exhaust......i installed it before geting stage one...and i noticed more low end power right off the bat....and better gas milage
Old Apr 5, 2006 | 09:09 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: stage 1
ORIGINAL: vaughn
Same here.
Dusty
Old Apr 9, 2006 | 12:41 AM
vaughn's Avatar
vaughn
Default RE: stage 1
ever since installing stage 1.my car has a horrible miss are loopy idle.....just now comming to a fairly hard stop..my car dropped down to sounding like it was going to stall.but recovered quickly.........im using ngk 4306 gapped .50 any suggestions??
Old Apr 9, 2006 | 08:04 PM
black4's Avatar
black4
Default RE: stage 1
the gap seams a little big you may wanna try using a smaller gap with your plugs.
