I GOT HIDs
Old May 29, 2004 | 06:31 AM
OASRT48U's Avatar
OASRT48U
Default I GOT HIDs
well i went to brightstar and i saw there hid kits they look awsome so i finally decided to get it it was like 400 with shipping and i think i wll have it tommorow well SATURDaY AND I WIL TAKE PICS. I GOT THE 8000 K LIGHTS IT IS MORE OF A BLUE BUT OT TOO BLUE IM SO EXCITED I THINK IT WILL LOOK BAD *** i also want to see if i can find some yellow fog lights i think that would also look good but if not i will get some blue blubs for the fog lights but i dont think they make them for the fog lights yet if ne 1 knows what size and if they last a long time let me kno
Old May 29, 2004 | 10:57 PM
Barneydriver's Avatar
Barneydriver
Default RE: I GOT HIDs
The size is in your owner's manual- check modernperformance for the foglight silverstars- they have the best price- they are bright white w/ a hint of blue.
Old May 31, 2004 | 04:47 AM
71RoadRunner's Avatar
71RoadRunner
Blue and yellow lights on the same car at the same time.....[:'(][:'(]Stick with the slightly blue ones.
Old May 31, 2004 | 01:06 PM
OASRT48U's Avatar
OASRT48U
like an is300 if you think an is300 looks like crap from the front
Old May 31, 2004 | 08:01 PM
megaman's Avatar
megaman
i went with the silverstars bulb swap for both the headlights and fogs, all for about $125. pretty easly install as well, just gotta be careful not to scratch the paint around the head light assembly well and get the alignment of the head lights just right. bright and white, with just a hint of blue....i like it.[&:]
Old May 31, 2004 | 08:29 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
I also have the Silverstars in my headlights and foglights... LOVE THEM!!
~Amanda
Old Jun 20, 2004 | 10:01 AM
WankerWeasel's Avatar
WankerWeasel
One of my coworkers installed Silverstars in his headlights and fogs on his new '04 Neon R/T and it looked sweet. But less then a month later they fried out his whole wiring harness and the dealership refused to replace it under warranty. He had to goto a junk yard and get one outta a car there and have them install it cause they wanted like $600 for a new harness. Then they got coolant all over the intake somehow while installing it so he had to make them clean the engine, and then the turn signals wouldn't work after they installed it and they tried to refuse to fix that. After tons of bitchin' they finally fixed all the problems. He's now stayin' away from Silverstars. Anyone else had problems with these? Anyone usin' those upgraded voltage harnesses avaliable for them? They're supose to make them brighter too.
Old Jun 20, 2004 | 03:05 PM
jackhole 101's Avatar
jackhole 101
I have never heard of sylvenia sillverstars hurting stock wiring...but I have heard that HID's will burn you stock light housings and screw up your wiring in a big way. Since they burn so hot, they will melt the laminate glue on the inside of your light houseing, making the reflective surface flake off and fall to the bottom
Old Jun 21, 2004 | 08:56 AM
71RoadRunner
HID's on a vehicle that didn't originally come with them are common for burning up wiring harnesses.
