oh geeeze.......
Old Apr 11, 2006 | 09:45 PM
wordslayer's Avatar
wordslayer
Default oh geeeze.......
Here's the deal.
My first performance modification arrived today. It is stage one. I am soooo tempted to do this install myself. I looked through the instructions and it seems a little hard, but doable.
Okay,,,,,this is what I don't understand. On the third page of the instructions, there is this part that says "air cleaner housing removal." I don't get that. This is the part that seems pretty complicated. If you replace the ECU, then you have to move where your air cleaner is?????? Am I understanding that right????
Old Apr 11, 2006 | 09:48 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
Default RE: oh geeeze.......
If am not mistaken, I think it is referring to the big *** stock intake box that comes with the car. Unless you have an aftermarket intake system. You need to move that in order to throw in the ECU.
Old Apr 11, 2006 | 09:51 PM
wordslayer's Avatar
wordslayer
alright izzy,,,,so what you are saying is that the stock airbox has to be relocated??? Dammit to hell,,,I knew there would be more to it than I thought there was.
The odd thing is,,,,if the air box has to be moved and all, then why aren't there other parts that come with it????
Old Apr 11, 2006 | 09:53 PM
vaughn's Avatar
vaughn
yes i just did mine......you have to loosen the air box unit enough to push it up out of the way. enable to get to your computer.. i didnt remove any wires really........i was able to get it up out of the way good enough.... it took less than a hour
Old Apr 11, 2006 | 09:54 PM
wordslayer's Avatar
wordslayer
it says to:
disconnect clean air hose from air cleaner housing
disconnect ambient air temperature sensor
remove turocharger solenoid bracket mounting screws
reposition turbocharger solenoid bracket
discommect make up air hose from the side of air cleaner housing
dislodge wiring harness clips on the side of the air cleaner housing
remove air cleaner housing mounting screw and nut
pull air cleaner housing straight up to remove
(this all has to be done to change out the ECU???)
Old Apr 11, 2006 | 09:55 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
You just have to move the stock intake box to get enough space for you to take out the stock ecu and throw in the stage 1.
wordslayer's Avatar
wordslayer
did you relocate your airbox or put it back in the same spot?
Old Apr 11, 2006 | 09:57 PM
wordslayer's Avatar
wordslayer
Ohhhhh,,,so I don't have to air cleaner housing removal thing! Good.
This is pretty simple then, right? If it isn't, tell me, cause I am going to try it if it isn't too hard!
Old Apr 11, 2006 | 09:58 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
It shouldn't be that hard, I helped my friend do his, it took 15-20 minutes tops, not that hard to do at all.
Old Apr 11, 2006 | 10:00 PM
vaughn's Avatar
vaughn
its not that hard really....
disconnect slolenoid bracket from air clean box and push out of the way
remove air cleaner cover......
remove 4 screws that hold air cleaner box in place
disconnect two wiring harness clips from side of air filter box
loosen air tube clamp and pull section apart
pull air cleaner box up enough to get it out of your way....becarefull not to disconnect any wires
then your ready to remove the computer mount
***BEsure to disconnect negative batter cable first***
