Is this legit?
Old Apr 12, 2006 | 03:20 AM
05dodgesrt4's Avatar
05dodgesrt4
Default Is this legit?
what do you guys think about this?
http://cgi.ebay.com/ebaymotors/SRT-4...spagenameZWDVW
Old Apr 12, 2006 | 04:11 AM
PSI Chick's Avatar
PSI Chick
Default RE: Is this legit?
i have that on my car. great check valve. i got it directly from pt performance, i didn't know they sold on ebay too.
Old Apr 12, 2006 | 05:23 AM
Four Banger Anger's Avatar
Four Banger Anger
is it hard to install...does it actually work psi chick?
Jordan, why does our stock pcv valve leak so much?
Old Apr 12, 2006 | 10:07 AM
vaughn's Avatar
vaughn
i also have this installed recommened by Amy..it took two minutes to install..
the directions show's you cutting the stock plastic tube going to the intake on car to install ....but i was able to install it without cuting anything..leaves a little bind in things but not bad
makes things easy if you decide to remove it back to stock
Old Apr 12, 2006 | 11:54 AM
PSI Chick's Avatar
PSI Chick
our stock pcv valve is the same one that dcx uses on regular neons and cannot handle the pressure of running so much boost. it gets worse the more boost you run. a check valve helps prevent boost from going back to the pcv valve. it installs in 2 minutes and is a good way to help protect the car from blow back.
Old Apr 12, 2006 | 01:28 PM
MChat's Avatar
MChat
I used 2 of these check valves. One for the PCV line and one for the brake booster line (I have an aftermarket boost gauge).
I got mine straight from McMaster:
http://www.mcmaster.com/ctlg/DisplCt...MainWidth=1060
Item #7775K53 - $18.92
And you'll need two 3/8 pipe - hose barb fittings per check valve. Which I picked up at the local Home Depot.
Just remember for both applications the flow arrow should point toward the intake manifold.
Old Apr 12, 2006 | 03:49 PM
rare04's Avatar
rare04
so in all honesty, does this work and is the one off e-bay ok to go with?
Old Apr 12, 2006 | 04:56 PM
PSI Chick's Avatar
PSI Chick
yes it works and the one off ebay is the same one that many of us use. ptperformance makes it, they are a vendor on many forums.
mchat - brake booster line....never thought of putting one there......i'm guessing it's working out for you?
Old Apr 12, 2006 | 05:14 PM
MChat's Avatar
MChat
ORIGINAL: PSI Chick
Ever hear of people blowing the line off of the brake booster and having to really push on the brake pedal to get stopped at the end of the strip?
Well, it never happens to me And I don't even have a zip tie around the brake booster connector anymore. I just used a couple of standard 3/8-1/2" worm gear clamps around the hose where it connects to the manifold and to the check-valve.
Old Apr 12, 2006 | 05:54 PM
rare04's Avatar
rare04
mchat-do you think that the one off ebay will work for the brake booster as well? and also do you have any pics of the mod?--Thanks
