Aftermarket IC ?
So i am gonna be ordering a new IC at the end of this week,im going with the Exhaust Depot BEAST FMIC
.I have stage 2 w/toys and i have been putting off installing the IC sprayer untill i got my new IC,will the IC sprayer mount to the BEAST FMIC?Will i have to do any modifications to the bumper?The other ? i have is on installing the IC sprayer do i have to cut a hole into the washer reservoir?Can i just mount the Pump where the pump for the washer sprayer is located?Thanks for any input
I have the AGP fmic and I love it, as far as the sprayer heres an idea, take the plastic mesh guards off the bumper and where the holes are to hold them in place you can place the sprayers there and run the lines to the pump along the channels on the inside of the bumper. As far as the pump, you can tap into the washer res on the bottom side, but there is some kinda in-line valve you must install to keep it from leaking out when not on. This set up is what I'm going to do in the near future.Late
i got the beast as well, great fmic you'll be happy with it.
if you don't want to drill into the washer fluid bottle just get a overflow tank from a local rice boys shop and use that. i had a 1/2 gallon one mounted where the stock air box was. worked just fine. i ended up taking out the ic sprayer when i installed the beast, never used it and i didn't feel like putting it back in. i think it would have fit just fine though.
