rookie: help
Old Apr 13, 2006 | 04:49 AM
dragon111203's Avatar
dragon111203
Default rookie: help
MY ? are is a pyle a good bov and why is my car breaking up in 4th. Its almost like shuts off when it starts getting up in boost like a govener and i am nowere near redline. I turned the boost bown to 17 and my codes say i have a vacume leak i need guidance before i blow sh*t up. I am not used to this so i need to slow down and get some info and some help from people who know what they are doing. Like i said i am rookie and i want a fast srt4. My goal is at least 380 to the wheel and i would be happy what do i need to get there thanks for everyones help. Drag-on
Old Apr 13, 2006 | 06:35 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: rookie: help
Did you ever take it to the dealer about the sensor? The camshaft sensor?
Old Apr 15, 2006 | 11:35 PM
dragon111203
i need to take of the mbc before i do that i now they are going to see the code for overboost should a clear the pcm or just let them see that let me now thanks again
Old Apr 16, 2006 | 01:34 AM
LilSparkPlug
Clear the PCM. Your better off. If they see a code for overboost, and ANYTHING is wrong with the head or its sensors...they wont do it. Pop that MBC off, take the ASD fuse (second one in from the right second row down in your Engine fuse box/PDC) out for a few minutes, then put it back in, and tally-ho to the dealer!!!
Old Apr 23, 2006 | 07:39 AM
dragon111203
i am taking of the mbc and I reset evrything i am making an appointment this week thank you
Old Apr 23, 2006 | 10:19 PM
LilSparkPlug
Lemme know how you make out.
Old Apr 23, 2006 | 10:22 PM
vaughn's Avatar
vaughn
can you unhook the negative battery to clear the computer too?? cause thats how i did it
Old Apr 23, 2006 | 10:25 PM
LilSparkPlug
Yes, but you have to leave it off for longer. The ASD fuse is the easiest.
