Wheel Shimmy?
Old Apr 18, 2006 | 09:18 PM
flameredsrt's Avatar
flameredsrt
Default RE: Wheel Shimmy?
What do you do for Porsche?I work at Mike Naughton Ford,im a service writter.
Old Apr 18, 2006 | 10:16 PM
vaughn's Avatar
vaughn
yea i read it in the other forum..and people were replying back on how it really worked.....remove the retainer clips.......the stock rims had a groove in them so it didnt effect them
Old Apr 19, 2006 | 02:12 AM
WhtLightning's Avatar
WhtLightning
If lowered too much, could be CV joint strain, if you have parked ... not so good, (kissed a curb), the stock tires (as well as most low profile tires) are prone to bruising, which causes a "bubble" to form on the sidewall. This causes shimmy at 80+ MPH. (the voice of experience) check the tires closely, it can be hard to spot.
Scott
Old Apr 19, 2006 | 05:05 PM
LilSparkPlug's Avatar
LilSparkPlug
Okay heres the things to do:
1. Remove the tinnerman nuts (speed nuts) one on each rotor underneath the wheel.
2. Grab some hubcentric rings if your wheels are aftermarket
3. ROADFORCE Balance the tires/wheels, thats the only way you'll ditch a high speed shimmy is with a dynamnic balance instead of a static balancer, however RF balancers are over 15grand and most shops dont have them.
4. Make sure none of the wheels are bent
5. Its unlikely an alignment would cause a shimmy, however it could, make sure everything is aligned properly and if you need a camber kit, buy the bolts, they're cheap enough and they'll help with tire wear.
6. Make sure none of the belts in the tires are bad.
7. Make sure none of the wheels are bent.
8. Make sure your brakes aren't warped either, the caliper banging against the rotor could also cause a wheel shimmy at higher speeds and it would have NOTHING to do with the wheel whatsoever.
Old Apr 20, 2006 | 06:31 PM
rare04's Avatar
rare04
well I found out what the deal was, the wheels have a runout in them. So the now its time to get some new stronger wheels. Thanks for the help forum.Later
