Yikes!
Old Apr 23, 2006 | 02:19 PM
wordslayer's Avatar
wordslayer
Default Yikes!
I took the car for a test drive this morning, because of how the car seemed to be pulling me all over the road. Here's what's happening. First, let me say that I put on a needswings downpipe last week along with a stage one chip.
The car is running like a light switch. When you get a little over half throttle, the boost gauge starts to peg and the car almost wants to jump out from under you. It's like it is all or nothing. The boost guage, literally, just flies around to the end of the guage. If you try to back off and hold it at three quarter's throttle, the boost guage will hang around at 17 or 18, but will shake like crazy. I think something I did wrong on the install of the downpipe and ECU really has messed it up. Any ideas on what I did wrong??? It is throwing no codes and the boost guage sits at 0 when the car is turned off.
Old Apr 23, 2006 | 04:58 PM
moparman04's Avatar
moparman04
Default RE: Yikes!
sounds like a busted intercooler pipe. i had the same problem with mine. the boost goes up to about 25 or 30 ... it wasnt even on the numbers anymore
Old Apr 23, 2006 | 05:48 PM
wordslayer's Avatar
wordslayer
Default RE: Yikes!
oh,,,something else, too. At part throttle and boosting around 15-18, the car is cutting out horribly.
Am going to look at the intercooler pipe. I=
Old Apr 23, 2006 | 07:41 PM
wordslayer's Avatar
wordslayer
Default RE: Yikes!
Okay,,,,just checked the intercooler pipes and they are both on and I couldn't see anything that looked like a hole or anything. There is also nothing leaking underneath the car. It's just boosting insanely high. If you go just a little over half throttle, it sounds like air whooshing and the boost needle just pegs itself.
What about resetting the pcm??? Could the computer just be out of sync or something???
Old Apr 23, 2006 | 08:27 PM
black4's Avatar
black4
Default RE: Yikes!
sounds like something is leaking bad from sound description an inability to regulate boost . have you checked the piping going from turbo to intercooler under heat shield?
Old Apr 23, 2006 | 08:48 PM
wordslayer's Avatar
wordslayer
Default RE: Yikes!
No,,,,I haven't checked that yet. I don't have any kind of way to lift the car, so all I can do is to barely get my head underneath it to look around. I did get underneath it earlier and I checked where the pipes went into the intercooler and they *seemed* okay. I have no other real way to get any further under the car to get a closer look. I parked the car in the garage with a sheet underneath the motor and nothing is leaking on it. I wish there was a way I could check it closer. But it is an intercooler pipe problem, right?
Old Apr 23, 2006 | 11:50 PM
black4's Avatar
black4
Default RE: Yikes!
i had an mr2 turbo years ago and when the piping from the turbo to the intercooler came loose it wasdoing exactly what you just described.
Old Apr 23, 2006 | 11:54 PM
wordslayer's Avatar
wordslayer
Default RE: Yikes!
do you think I could hurt the car driving it several miles to my dealer? it's like 60 miles to get there.
Old Apr 23, 2006 | 11:58 PM
black4's Avatar
black4
Default RE: Yikes!
if you can keep it out of boost i wouldnt recomend it other wise you could over speed your turbo since you describe it not regulating boost.
Old Apr 24, 2006 | 12:02 AM
wordslayer's Avatar
wordslayer
Default RE: Yikes!
Oh,,,I will keep it out of boost. Soooo,,,it will be okay to drive it till I get it to the dealer then?
