exhaust
Old May 1, 2006 | 11:16 PM
mpplaya07's Avatar
mpplaya07
Default exhaust
Would you guies recomend a 2 1/2 inch exhaust or a 3 inch pipe one?
Old May 1, 2006 | 11:59 PM
Burnout_INC's Avatar
Burnout_INC
Default RE: exhaust
factory is 2 1/4, anything worth doing is worth doing right... misewell go 3 if you're gonna be paying for a new exhaust.
Old May 2, 2006 | 12:29 AM
carcrazy's Avatar
carcrazy
Default RE: exhaust
depends on how far you wanna take your power.. if you plan on upgrading turbo going with stage 2 or 3 probally best for the 3inch if plan on running pretty much stock stay with 2 1/2
Old May 2, 2006 | 12:37 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: exhaust
A 2 1/2 inch is fine for anything up to and around 300 horsepower. Anything higher than that will run better on a 3 inch system. If you're going to go full bore on your mods, go three inches, otherwise, save some cash and go with the smaller size......
Dusty
Old May 2, 2006 | 01:51 PM
MChat's Avatar
MChat
Default RE: exhaust
WhiteMnt's car ran low 11's on the Mopar 2.5" Cat Back
I would say go for the 2.5" unless you're planning on making more than ~350whp.
The 3" will take you up to the 550-600hp range.
I'm looking into a 3.5" exhaust for my car, and will likely go that route.
