Fuel Problems
Old May 7, 2006 | 05:17 PM
DominicanSRT4's Avatar
DominicanSRT4
Default Fuel Problems
I was at the dyno the other day trying to go up on boost on 57trim turbo. I have the Walboro 255, Fuel return kit, and 750cc injectors. I set my idle fuel pressure to 58. When i go on boost, my fuel pressure isnt moving from 58. The dyno people told me my fuel pressure regulator was messed up, i bought a brand new 170$ fuel pressure regulator and same thing. Is this the limit of the walboro fuel pump? or Is there a fix to this? How bout the mopar fuel pump, it says its rated up to 75psi of fuel pressure?
Old May 8, 2006 | 01:33 PM
PSI Chick's Avatar
PSI Chick
Default RE: Fuel Problems
mopar one is a 190lph pump but can handle a higher pressure. stick with the 255, better flow.
are you sure that there isn't an issue with the fpr? sometimes they can leak out the back fitting and cause a issue with pressure. you also might be having an issue with the "bottleneck" in the fuel system. realtune has a fix for that....
Old May 8, 2006 | 07:22 PM
rare04's Avatar
rare04
hows the process with installing the fuel pump. Easy or a pain in the a--?
