Widest Tires??
Old May 14, 2006 | 11:59 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Widest Tires??
what all setups have experienced yall rubbing with (wheels, tires & suspension) and what setups are pretty good?
Old May 15, 2006 | 12:56 PM
MChat's Avatar
MChat
245/40R17 BFG KDW's on 5Zigen FN01R-C 17x8" wheels w/ a 35mm offset.
With the stock suspension (stock springs) and with the coil-overs (set about .5" lower than stock in the front, 1.5" lower in the rear), I have experienced no rubbing.
With the Hotchkis lowering springs on, every once in awhile I'd hit a bump just right (usually when I had a passenger in the passenger seat) or come around a corner just right and the passenger front would barely rub.
