Tranny Fluid
Old May 18, 2006 | 01:52 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Tranny Fluid
i felt motivated so i aslo changed out the sxt oil and tranny today. but dang, it was much more of a pain to refil the trans on the sxt.
btw, anyone else hate trying to get the oil filter wrench on and off of the srt???
Old May 18, 2006 | 02:10 AM
`71RR383SRT4's Avatar
`71RR383SRT4
You use a wrench??!! I didn't know there was a tool for the filter. I've been using a a pair of channel locks............................................. ..................[:@]
Old May 18, 2006 | 03:29 AM
PSI Chick's Avatar
PSI Chick
the additive does absolutely nothing to help the lsd. all that it actually does is reduce the noise that the dif puts out. it's for comfort purposes only. so if you don't want it in there, don't put it in. it's not going to affect anything. most of the aftermarket fluids like redline and synchromesh have the additive included in the fluid already so don't bother if you go with one of those.
LilSparkPlug's Avatar
LilSparkPlug
All else fails a flat head and a hammer LOL!!!
Old May 18, 2006 | 04:17 AM
Andy4.7's Avatar
Andy4.7
ORIGINAL: flamingpinhead
The K&N filter has a 1" nut welded to the end... Makes taking it off very easy.
Old May 18, 2006 | 12:16 PM
RIPSIGUY's Avatar
RIPSIGUY
The additive actually has nothing to do with either gear rattle or LSD.
Each blocking ring (or stop ring) in the syncros are coated with clutch type material where they mate against their respective gear. The additive is friction modifier to enhance the performance of the syncro.
Thats it, end of story. We used to use it in the Getrag gear box for the Stealth Twin Turbo, same reason. I U don't use it, you risk syncro failure or hard shifting.
Old May 18, 2006 | 12:44 PM
PSI Chick's Avatar
PSI Chick
no actually that's not what it's for, and both the SRT (PVO/whatever) team and Quaife have said so. it's only for creature comforts to make the lsd a little quieter. if the additive were for the synchros then the 03's would have to use it as well. it's ONLY for the lsd, and ONLY to make it quiet.
Old May 18, 2006 | 02:12 PM
flamingpinhead
Section Moderator
ORIGINAL: Andy4.7
i have used those before, i got it from autozone and they told me it came with some krazy warranty. i took it back every time i changed my oil for like a year... it helped to offset the initial cost considering i got like 2 or 3 for free.
Old May 18, 2006 | 05:15 PM
Plan B's Avatar
Plan B
ORIGINAL: RIPSIGUY
ORIGINAL: PSI Chick
Good arguments/input. Now on who to believe.... The Nextel Cup Series Champ or the Truck Series Champ? lol
Old May 18, 2006 | 06:31 PM
Andy4.7's Avatar
Andy4.7
? You took the used filter back, and got a new one every oil change? Is that what you're saying?
