04 Srt-4
Old Jun 8, 2004 | 11:42 PM
integra29's Avatar
integra29
Default 04 Srt-4
Is anyone else having motor mount problems, Ive been through 2 sets of stock now. If i wheel hop one time it kills them.
[IMG]local://upfiles/4636/Yw692167646.jpg[/IMG]
Old Jun 9, 2004 | 04:10 AM
Bildo's Avatar
Bildo
Default RE: 04 Srt-4
I know I hopped pretty bad a few times at the track. I don't know what or where the motor mounts are, but my car is still running fine.
Bildo
Old Jun 9, 2004 | 09:15 AM
71RoadRunner's Avatar
71RoadRunner
There are a couple cheap and easy solutions, motor mount inserts or the Rex motor mount inserts that don't require you to remove the mounts to put them in. After they are in, you cannot tear the rubber in them anymore.
Old Jun 10, 2004 | 12:46 AM
1qwk4's Avatar
1qwk4
do not use the REX inserts.it will tear up the rubber as you up the power of your srt. use the filled motor mounts sold at NEONPARTS.NET they work great. from personal experience
Old Jun 10, 2004 | 07:37 AM
71RoadRunner
Really. That's the first that I've heard of that happening. Modern Performance has them on two week back order right now. The ones I had on my R/T worked great without any problems after 4 years of use. I'll have to check that out, thanks for the info.[sm=smiley20.gif]
