What are these free mods i hear about?
Old Jun 1, 2004 | 09:35 PM
bda1855's Avatar
bda1855
Default What are these free mods i hear about?
I keep hearing about the spring mod and the $1 T fitting mod? what are these? and what are all the Free mods out there?
Also which ones are crap and which ones work.. LOL I am interested to know what will help for free...
Old Jun 1, 2004 | 09:46 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: What are these free mods i hear about?
I haven't heard or seen a thing...I was at the dealer today looking thru their inventory, no mention of anything like it anywhere. They did have a half dozen SRT-4's in stock (a record) all with the sunroof and the kicker stereo....$22,485 plus TTL (no dealing).[&:]
Old Jun 2, 2004 | 01:23 AM
Barneydriver's Avatar
Barneydriver
spring mod is for your wastegate- keeps the boost higher/more consistent- don't know the T mod- check out SRTforums.com
Old Jun 2, 2004 | 01:31 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
How does this apply to previously bought cars?
Old Jun 2, 2004 | 02:06 AM
Barneydriver
not sure what you mean...
Old Jun 2, 2004 | 06:30 AM
71RoadRunner's Avatar
71RoadRunner
The spring mod seems to only work for a short period of time, because the PCM will eventually correct itself, thus nulifying your mod.
I haven't heard of the T fitting mod, but if it's what I think it might be then it is very bad advice. You can get alot more boost by fooling the PCM into not seeing how much boost it is actually putting out. One way of doing this is by putting a bleeder or small orifice (small tube or fitting) into the wastegate vacuum line, so that the PCM doesn't "see" as much boost as the turbo is actually putting out. Or something to this effect.
Old Jun 10, 2004 | 03:22 AM
PSI Chick's Avatar
PSI Chick
the spring mod is the wga spring adjustment.
welfare exhaust is the removal of the spaghetti section of the exhaust, however some people remove everything from the dp back.
welfare cai is a hole cut in the bottom of the stock air box.
hood mod is removing the plastic piece in the hood to allow for more air flow.
i would seriously not suggest a bleeder valve. there is no way to control boost levels with this mod, and i've already seen one kid blow his #4 cylinder because of this. don't be bootleg, get a mbc. they're like $20 on ebay....
Old Jun 10, 2004 | 07:42 AM
71RoadRunner
Yep, that's why I said it's very bad advice. Doing this will lead to over boosting without the needed added fuel causing a lean condition and the engine will go BOOM!!!!
