tires
Old May 24, 2006 | 12:53 AM
Pressurecooker's Avatar
Pressurecooker
Default RE: tires
My Fuzion ZRI's are excellent. Way better than the stock KDW's. Sticky, quiet, Z rated and good riding. Tead wear is ok, but I drag race and do burnouts, so mine is suffering, but they have gotten me a 1.99 60 ft time and that's very good. Very happy with them. Also not terribley expensive.
[IMG]local://upfiles/15665/A00A976BD47943F9AC2577190E5D618F.jpg[/IMG]
[IMG]local://upfiles/15665/675A28C0FB4A438C819149E89B189B30.jpg[/IMG]
Old May 24, 2006 | 03:27 AM
PSI Chick's Avatar
PSI Chick
Default RE: tires
kdw's are like 130 each...i paid 145 for my f1's, not exactly a ton more for a much better tire imo/ime......
Old May 24, 2006 | 09:02 AM
FiberSRT4's Avatar
FiberSRT4
Default RE: tires
ORIGINAL: PSI Chick
x2
they are basically one step below drag radials and they will last a while
Old May 24, 2006 | 05:25 PM
Plan B's Avatar
Plan B
Default RE: tires
ORIGINAL: Racevette77
ORIGINAL: Plan B
I agree with ya Racevette! The same reasons you'd want a performance tire are the same reasons they won't last that long! I loved them when I had the stockies, but got a wider setup and may have to get another set down the road......
With the wider set up im sure you have a substantially better launch.
With the wider set up have you noticed any negitive effects?
Definately a better launch! And less wheel hop.... Looks better too! I had to put the stockies back on after I broke a rim in half in a wreck on the freeway, and they just looked too skinny...
As far as negative side effects, I have yet to see any. I imagine with the wider tires it might lower the gas miliage, but if so it is so minute that it isn't noticable.... I highly recommend going wider than the stockies, which is what they should of done in the first place!
Old May 24, 2006 | 07:00 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
Default RE: tires
What dimension are our stock wheels?
17x6?
I am planning on getting some rims that are 17x7.... not to sure yet.
Old May 24, 2006 | 07:53 PM
FiberSRT4's Avatar
FiberSRT4
Default RE: tires
the only down fall of too wide of tires is they can rub if your car is lowered they might rub onthe fenders but you can have your fenders rolled and that takes car of it
