Stage 2 Question???????????
I don't want to steal this guy's thunder, but I'd like to get an answer about the Stage 2 (No toys) ...how much HP would I be missing out on if I didn't change the stock exhaust out to something like the performance Mopar cat-back?
I'd like to stay away from the interior buzzes and rattles that usually come with performance exhaust systems. Thanks.
PSICHICK:I saw you said something about running a D-TECH on a stage 2 w/out toys to lean it out,can you run a S-AFC or a D- TECH on a TOYS setup to get any gains out of it?I was thinkin about gettin a SAFC but if its not gonna do anything i would like to know...
safc's are made by the devil. i hate those things. they're cheap for a reason.
if you're going to run anything dtec seems to be the best option. emanage/e01 combo is nice, but a lot more money. using a piggy back on s2 w/toys will also help lean it out as the purpose is to control fuel delivery, the only issue is that you'll loose the functionality of the dail-a-boost. if that doesn't matter to you, then go for it. if that does matter, then stick with the dab and use a tb, exhaust, and w/i to help lean it out.
i'll be putting a dtec on my car in the near future, as soon as my fuel system comes in.....
it changes depending on if you're running s2 or s3.....
from what i remember when i was on s2, my car ran as follows
0 - 7psi
1 - 15psi
2 - 1st & 2nd gears 14psi, 3rd & 4th 19psi
3 - 19 all gears
0 - 7psi
1 - 15psi
3 - 19 all gears
