UPSET WITH DYNO NUMBERS.
Old May 28, 2006 | 09:49 PM
street demon's Avatar
street demon
Default RE: UPSET WITH DYNO NUMBERS.
YEA IM ABOUT TO GO AND GET NEW PLUGS RIGHT NOW BUT WHICH ONES SHOULD I GET AND WHAT SHOULD I GAP THEM AT. OH YEA I WAS TOLD THAT MY CAR IS RUNNING WAY TOO RICH TOO. WHY IS THAT?
Old May 29, 2006 | 06:00 AM
Four Banger Anger's Avatar
Four Banger Anger
the car runs way to rich from the factory, it helps for gas so that you dont have to use the highest octane all the time. Anyways you can fix that with proper tuning and make some good power out of it. For plugs i recomend Champion copper plugs 570....I say gap at 45 or 40 depending on what you have done to your car. I know alot of guys say they work the best and get rid of any stuttering that you may have with your old plugs.
Jordan
Old May 29, 2006 | 12:49 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
more infor on leaning out the motor???
Old May 29, 2006 | 02:15 PM
PSI Chick's Avatar
PSI Chick
you have a boost leak. why does everyone try to make things way more complicated than they are?
Old May 29, 2006 | 08:53 PM
Nicky B's Avatar
Nicky B
ORIGINAL: dustyloins
ORIGINAL: moparman04
the weather affects oue car really bad too. ive felt significant power losses in colder weather
That's weird. My car always runs better (faster) in the colder weather......."cold" down here is 35-40 degrees......
Dusty
Your car would run better cold cause the colder air keeps the turbo cooler and not get to hot at all.
Old May 30, 2006 | 12:46 AM
street demon
YOUR TELLING ME I HAVE A BOOST LEAK! AND HOW CAN I FIX THAT?
Old May 30, 2006 | 12:55 AM
05dodgesrt4's Avatar
05dodgesrt4
hold on man you dont know that you have a boost leak you never stated what you were boosting so how could she possibly accurately determine it was boost now what were you boosting at the time then we can determine what it was no sense in going on a wild goose chase
Old May 30, 2006 | 01:46 AM
street demon
IM BOOSTING AT THE STOCK 15PSI
Old May 30, 2006 | 01:54 AM
street demon
MAN I WISH I COULD JUST GET WITH ONE OF YOU GUYS FORM THE FORUM. YOU KNOW SO THAT YOU GUYS CAN SEE MY CAR FIRST HAND AND TELL ME WHERE TO GO FROM THERE. BECAUSE TRYING TO EXPLAIN THIS **** IS JUST TOO HARD. DOES ANYONE LIVE ANY WHERE CLOSE TO MY (714) AREA IN CALIFORNIA. NEED HELP!
Old May 30, 2006 | 02:14 AM
mxrnick's Avatar
mxrnick
what city do you live in? i live in Newport. im still learning with my srt-4 still too, but i need to go to a dyno sometime cause my car will not hold boost till redline.
