Whats your best time?
Old May 31, 2006 | 02:47 PM
Valo2170's Avatar
Valo2170
Default Whats your best time?
i just wanted to know everyone best time in there srt-4.Just wanted to know also if im where i should be with the mods i have.mm,fmic,wga,intake and on strret tires with no spray. 13.2 does that sound right to you guys?
Old May 31, 2006 | 05:55 PM
Valo2170's Avatar
Valo2170
Default RE: Whats your best time?
what know one wants to say there times LOL
Old May 31, 2006 | 07:19 PM
PSI Chick's Avatar
PSI Chick
no that doesn't sound right at all actually....the only power maker you have is the wga and fmic, not even stage 1. 13.5 would be more likely than a 13.2....
Old May 31, 2006 | 07:30 PM
Valo2170's Avatar
Valo2170
well i said i also have a full 3in turboback .Does that not do anything? If you want i will put the slip on here so you guys know im not lie LOL , i guess im just a good driver.But like i said i just dont have a wgw and fmic.I have MM and turboback.Im sure all those things ad up together.I know when i 1st got my car Bone stock i hit a 13.9
Old May 31, 2006 | 07:39 PM
PSI Chick's Avatar
PSI Chick
13.9 stock is not uncommon.
a turbo-back isn't going to help THAT much on a basically stock car. i believe you that you ran a 13.2, i just think it was probably one of those freak runs where everything went perfect for you. i can't see you running that consistantly on that set up......if you can, awesome for you!!!!
Old Jun 1, 2006 | 01:31 AM
Pressurecooker's Avatar
Pressurecooker
13.2 is good for a stage 0 with no ecu or fuel sys upgrade. I went 13.8 with only a 225 tire as a mod, motor untouched. I have gone 13.6 now with a K&N filter in my stock airbox as the only power adder. Could I go 13.2 with all the mods you have? I don't know. But PSI chick is right, a LOT of cars go 13.9 stock. Still, 13.2 is 13.2 and that's not bad. My best 60 ft is 1.99 with my 225 street tires. What's yours?
Old Jun 1, 2006 | 11:42 AM
Valo2170's Avatar
Valo2170
i dont know what it was right now im at work but as soon as i get home i will put it up here.I think i know how to do it LOL.And to psi,I was geting like 13.4-13.5 then i learn how to shift right and i got a really good take off.I still get that time almost every time i go now.And i got my car dyno when i 1st got it it was 227hp and then i got my turboback on with the intake and there was a 13hp change.LOL every little bit counts.My car dyno 275 i think.Does that sound right also?
Old Jun 4, 2006 | 01:23 PM
04srt4lvr's Avatar
04srt4lvr
i ran a 13.2 also with the same mods you have....strange!
Old Jun 5, 2006 | 11:57 AM
RIPSIGUY's Avatar
RIPSIGUY
12.95@106.1, 1.73sec 60'
100 octane.
Old Jun 5, 2006 | 01:08 PM
Valo2170's Avatar
Valo2170
you lie!there is no way you could run the saome thing i had ran.I hate you,you you dirty man LOL.j/k see you tonight rob.
