AGP work with DAB?
Old Jun 10, 2006 | 11:15 PM
winniep's Avatar
winniep
Default RE: AGP work with DAB?
So have you tried to hook it up using stock lines yet?
Old Jun 11, 2006 | 01:07 PM
PSI Chick's Avatar
PSI Chick
ORIGINAL: winniep
PTB worse than stg 2 WGA?
what ptb? there isn't any on the stage kits...that's the advantage of them when keeping the stock lines.......
Old Jun 11, 2006 | 05:07 PM
winniep's Avatar
winniep
I still have ptb on my stg 2. I also had it with my stg1 with stg 2 WGA. Would the AGP benefit me at all, or am I just better off keeping the stg 2 WGA? It is adjusted as far as it will go and still seems like it could use another turn or so....
Old Jul 17, 2006 | 12:41 AM
winniep's Avatar
winniep
So is the AGP hooked up on stock lines better than the Stage 2 WGA?
Old Jul 17, 2006 | 03:46 AM
hozay@N2MB's Avatar
hozay@N2MB
winniep, sounds like your either missing some stock vacuum line or you just don't have it hookd up correctly. The AGP wga will make a difference on your S2 w/ toys and DAB will work. We've used aftermarket wga's numerous times on s2 & s3 car's and have seen tremendous results. Also, make sure that your AGP wga is in fact working correctly. Sometimes the simplest mistake such as being on too tight or too lose will hurt performance.
