Vacuum Pressure?
Old Jun 10, 2006 | 12:44 AM
JLHILL's Avatar
JLHILL
Default Vacuum Pressure?
Ok after I installed my OCC, I noticed my vac pressure running around 18 at idle with the AC on, if I turn the AC off it goes to 19 -20. I know at idle it is supposed to be 20. Is this okay and me just being paranoid, or should I check for a leak. I know that its close enough to 20 but I just want to make sure.
Old Jun 10, 2006 | 09:43 PM
04-SRT-4's Avatar
04-SRT-4
Default RE: Vacuum Pressure?
with my mods mine runs at about 18-19 vac at idle.. i don't think theres anything to be worried about unless your getting a significant difference in vac
Old Jun 10, 2006 | 10:37 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Same here. Mine's always at 18-19. It IS a good idea to check those hose clamps on the OCC on a regular basis, though....
Dusty
Old Jun 11, 2006 | 11:47 AM
JLHILL's Avatar
JLHILL
Ok, thanks guys. Yea I have been checking my OCC and hoses about once a week. Thanks for the help.
Old Jun 11, 2006 | 05:27 PM
mpplaya07's Avatar
mpplaya07
my is past 20... it usually varies from 22 to like 28 but its always diff on the weather and the only thing i got was a cai and a bov
Old Jun 12, 2006 | 03:26 AM
LilSparkPlug's Avatar
LilSparkPlug
At idle vac is less than atmospheric pressure, which is 17-21mmHg
When you let off the gas it WILL go higher than 21mmHg
