Brake Light
Old Jun 26, 2006 | 01:58 AM
Downy123's Avatar
Downy123
Default Brake Light
Recently I have been having a problem with my brake light coming on when i accelerate. I was wondering if anyone else has had this happen to them. When it comes on it only happens for a little bit but its starting to **** me off. If you have any ideas please gimme a hand. If not ill bring it into dodge and have them check it out..thanks
Old Jun 26, 2006 | 02:12 AM
rare04's Avatar
rare04
Default RE: Brake Light
your resavoir for your brake fluid is low. top it off and it will go a away. Happens to all of us every once in a while. Late
Old Jun 27, 2006 | 09:24 PM
Downy123's Avatar
Downy123
Went to get my oil change and i asked the people at dodge to top off my brake fluid and of course they didnt so i was wondering what kinda brake fluid i need. It says in manual to use mopar but i wanted to know if there was something i could pick up at pep boys that would work just the same
Old Jun 27, 2006 | 10:30 PM
PSI Chick's Avatar
PSI Chick
dot +4
Old Jun 28, 2006 | 12:39 AM
moparman04's Avatar
moparman04
dot 4 brake fluid.. just a shot or two in there will make the light go off
Old Jun 28, 2006 | 03:37 PM
ToughLove's Avatar
ToughLove
Yeh, this has been happening to me for some time now. I think it has something to do with a sensor on the emergency brake linkage. The dealership says it will cost me about 90 dollars to fix. So far, I have been living with it.
Dave D.
Old Jun 28, 2006 | 06:15 PM
flameredsrt's Avatar
flameredsrt
ORIGINAL: ToughLove
Dave D.
Refer to RARE04's post and try that,thats what mine was doing and i topped her off and it hasn't came back since.
Old Jun 28, 2006 | 08:12 PM
LilSparkPlug's Avatar
LilSparkPlug
Read the top of the M/C its DOT 3. Read the top of the clutch fluid resivor....also DOT 3.
You can top it off with 4 if it isnt too low, if you need alot DONT mix them, they aren't meant to go together.
