DID I DO THIS WRONG?
Old Jun 22, 2004 | 02:37 AM
SRTUNIT's Avatar
SRTUNIT
Default DID I DO THIS WRONG?
Take a look at my catch can hoses. Did i hook this up wrong or what? let me know plz.
[IMG]local://upfiles/3526/Ki183349591.jpg[/IMG]
Old Jun 22, 2004 | 02:43 AM
roachnigga's Avatar
roachnigga
Default RE: DID I DO THIS WRONG?
I got the same injen CAI.. but, i dont see your OCC. my set up (OCC) is on the same location where my CAI is. look at my pic @ "S2 INSTALL/engine make over (pics)". it may help if you lookin for the same spot.
Let me know Wassup
Old Jun 22, 2004 | 07:07 AM
71RoadRunner's Avatar
71RoadRunner
What kind of OCC do you have? It is set up different than most, but it is indeed hooked up properly, most simply do like I did and mount it on the passenger side and have it coming straight out of the PCV valve into the OCC and then into where the hard plastic line came up to the PCV. Here is a pic of how mine are ran, I have 2 though, the one that is hooked up to the same line yours is on, on mine it's on the passenger side attached to the A/C line and the other is for the line/hose from the drivers side of the valve/cam cover that goes into the CAI tube and is mounted where your OCC is:
[IMG]local://upfiles/193/Bz795892316.jpg[/IMG]
Old Jun 22, 2004 | 10:39 AM
byebye's Avatar
byebye
RR,
You left the filter in the bottle? I took mine out because I heard that it doesn't work as well with it in. I don't have the filter anymore if I had to put it in. I did notice that after I emptied it the next day was like an 1/8 full.
Old Jun 22, 2004 | 03:23 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I heard/read the same thing on the other forum, so I took mine out as well......[&:]
Old Jun 23, 2004 | 12:58 PM
71RoadRunner
Have you ever blown through one with and without the filter, there is little to no restriction from the filter. And the presence of the filter isn't going to negatively effect the OCC's ability to catch the oil, in fact having it in place may help. I noticed how when under vacuum it is possible, however very unlikely, for the oil to hit the flat area by where the other opening is and as it would form a drip, indtead it could be pulled around around it and out into the intake as it did before the OCC. But as I said, it's highly unlikely. Either way it works great.
Old Jun 23, 2004 | 01:10 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: 71RoadRunner
No, RR, I haven't ever had the urge to do that!!!!![sm=smiley36.gif][sm=smiley36.gif][sm=smiley36.gif]
Seriously, what are you doing up at this hour??!?[sm=smiley20.gif]
Old Jun 23, 2004 | 01:50 PM
71RoadRunner
When possible, I like to make sure something works before I put it to use.[sm=smiley2.gif]
Lack of sleep the last couple nights caught up with me, so I gave in and went to bed at a human time and now I'm up at a human time. This has got to stop, this being human.[sm=smiley36.gif][sm=smiley36.gif]
Old Jun 23, 2004 | 01:54 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
And you won't be "invisible" in your SRT-4 during the day, either!!!![sm=smiley36.gif]
Old Jun 24, 2004 | 02:53 AM
71RoadRunner
Your right, that why it's back to the nights for me.[sm=smiley2.gif]
