Mopar BOV - Lucky...So far
Old Jul 28, 2006 | 06:13 PM
MEandmySRT's Avatar
MEandmySRT
Default Mopar BOV - Lucky...So far
Just took a break so I could check the "How To" section about the BOV gasket, and just wanted to mention that I had the BOV off and ready to install the plate...in only 15 minutes! Worked on the "hard" bolt no more than 3-4 minutes using the 10mm flex-gear wrench and sneaking in from under and behind, like the girl in the photo.
--->Edit<---
Took about an hour total, because I was more careful (slower) putting it back together and I was "detailing" under the hood as I went. Already scared I kid on a bike.
Old Jul 29, 2006 | 03:15 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Mopar BOV - Lucky...So far
Bike riders and joggers are fun! Did you use any Permatex sealer on the gasket?
Dusty
Old Jul 29, 2006 | 06:19 AM
LilSparkPlug's Avatar
LilSparkPlug
I used the permatex sealer, and put mine on in January of 05....I'm running 19lbs through it now with no leaks whatsoever, and its been swapped from one stock turbo to a new one.
Old Jul 29, 2006 | 12:46 PM
MEandmySRT's Avatar
MEandmySRT
ORIGINAL: dustyloins
Dusty
I used Loctite's new "stick" stuff so I wouldn't have a big smeary mess - used the smallest bit of the orange "flange sealant" on the gasket area at the turbo. Also used a thin layer of the "hi-tack" between the plate and gasket.
Old Jul 30, 2006 | 08:56 AM
71RoadRunner's Avatar
71RoadRunner
So long as you didn't overtighten the bolts reinstalling it you should be fine and leak free.
BTW: Nice picture of Lorissa McComas as your avatar.[sm=smiley20.gif]
Old Jul 31, 2006 | 11:28 AM
MEandmySRT's Avatar
MEandmySRT
ORIGINAL: 71RoadRunner
I tried to not tighten too much, but I'm not sure. Would I hear a leak, or do I need to use a leak detector?
And about the Avatar, I got the idea when I first came here and thought someone was using a Lorissa photo in their signature and then I thought it was pretty cool how someone got Lorissa to pose in front of their SRT4...and then I finally figured out that the person in the photo wasn't Lorissa and was actually a photo of LilSparkPlug - even cooler. Takes me a while to catch on sometimes.
