Check Engine Light and Running Hot
Tranny fluid should be changed every 12-18k.
You should've changed your spark plugs and wires (don't listen to the manual on this one the factory stuff is ****).
Oil every 3k with Full Synthetic.
Check your PS fluid, if its not full top it off (ATF)
Top off your Clutch Fluid (DOT 3 Brake Fluid)
Top off your Brake Fluid (DOT3)
Same with the last two, if they're at the fill line you can leave them alone, but if they need a bit, just add some, it wont hurt.
Thats all I can think of right now
